wowens79's avatar
wowens79
Explorer III
Nov 20, 2016
Winterizing toilet??
When winterizing, do you leave the pink stuff in the toilet bowl?? I've read the seals need to stay wet, but will the pink stuff damage them? Will it stayin the toilet bowl punk?
  • bobndot wrote:
    Whichever RV antifreeze you choose, just drain it all out after you put it through your system.
    Why would you need to leave it in the water lines , pump and fixtures once you have put it through to protect them ? At that point, the antifreeze has diluted any residual water left in the system , just get rid of it once it has done its job and you won't have to worry about any taste come spring.
    If you choose to do it this way, then lubricate the seal separately .
    re: toilet seal lubrication , read the post by jeepbluetj :B
    https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/25011836.cfm
    That is an interesting thought flushing it out immediately. However Glycol Antifreeze does not dilute (strictly speaking) it displaces water, they do not mix. I don't know if it is a me thing, a north thing or a Canadian thing, but when we regularly get double digit negatives, sometimes for a week or more at a stretch, it is nice to know that the antifreeze will displace any left over water that may be lurking somewhere that blowing out or flushing out did not catch. We usually do not have access to a dump again until our first spring trip anyway so no rush to get rid of it.
  • Whichever RV antifreeze you choose, just drain it all out after you put it through your system.
  • MFL wrote:
    If you use the cheap ethanol based anti-freeze, it may dry out seals, and will evaporate. It only takes a few gallons to winterize, so I don't mind paying 5 bucks a gal, for higher quality. It won't evaporate, won't stain, and is actually a good lubricant for seals.
    Jerry
    The higher quality (Glycol) is mineral oil based which is why it is good for the rubber seals. Downside is it is not as easy to find and costs 4 times as much. The other good side effect of Glycol is that it actually tastes quite good and does not leave that Antifreeze taste in you fresh water lines...
  • If you use the cheap ethanol based anti-freeze, it may dry out seals, and will evaporate. It only takes a few gallons to winterize, so I don't mind paying 5 bucks a gal, for higher quality. It won't evaporate, won't stain, and is actually a good lubricant for seals.
    Jerry
  • Anonymous's avatar
    Anonymous
    Not applicable
    I run pink thru the toilet system and leave some in the bowl. I also pour a little olive oil and flush it to help the seal.
  • I've been using pink stuff in the toilet bowl for years. No staining and no other problems.
