anutami's avatar
anutami
Explorer III
May 23, 2014
Wolf Creek 850 Water Leak!!!! Help
Well found my first issue since picking up my camper 2 weeks ago. I wanted to re-check the wiring under the bed step and noticed the bottom wood was discolored and looked saturated. I put my hand under fresh water tank and the insulation was saturated with water! I have yet to hook up to fresh water and only used the camper with the water pump. I have had the water pump on all day and it has not been cycling on and off. I looked at the top of the fresh water fill and there was moisture around the stainless band and tank. It appears the band is loose and while driving around the water sloshed out. I have only filled the tank 1 time and filled to the point of water overfilling the fill. Could the negative pressure have caused the problem on a stainless steel band?
My question is how do I get the moisture out of the basement of my camper?
My basement
Moisture under the fresh water tank
Water around the fill inlet
Removed and reinstalled fill
Thanks in advance
Nolan
