Gald65
Jan 18, 2020Explorer
Would I ever be happy towing with a half ton truck
Back story-impulsively purchased a 2006 keystone 26tbl. Loaded weight about 7700 lbs. At that time towing with a 08 Sierra cc. Obviously not enough truck. Purchased a 11 Sierra Denali cc with the 6.2. It definitely does much better. It has plenty of motor but the handling leaves a little bit to be desired.
The question- eventually I plan on upgrading my trailer to something that has a loaded weight of around 8500 lbs. I know that I won’t be happy with the Denali. Is anyone out there towing that type of weight with one of the newer F150’s with the 13000lb configuration? Are you happy with the handling? Should I stop being a tight a$$ and get a 3/4 ton truck?
TIA
TIA
