JimK-NY
Mar 31, 2023Explorer II
You already have a simple way of putting strings on the ground to help with alignment while backing up.
Tie a long string to the back jack. I use one about 30' long. Stretch it forward until it just touches the forward jack. You can then tape it to the ground temporarily. Do the same on the other side. Just back up keeping the wheels of the truck centered between the strings. This works well but you do need to stop occasionally and check the truck's position.
I have tried numerous other methods including using a laser pointer but none have worked as well as the strings. Unfortunately I have an older camper and a newer truck (with a narrow tailgate opening). I only have about 1/4" of clearance so loading is a real challenge.
About Truck Camper Group
300 PostsLatest Activity: Aug 21, 2026
