mkirsch
Apr 03, 2023Nomad II
JRscooby wrote:mkirsch wrote:
I'm not seeing how a line on the ground will help. Can't even see the ground from the driver's seat, and even if I could, what would I line up against?
Everyone's situation is different to a degree. In my case if I squeak between the jack feet with my tires, I'm lined up.
Most vehicles I have driven have mirror adjusted so can see sidewall of rear tires.
Squeak between jacks at wrong angle could have issues. I can see how something to line up on so going straight at start of squeak would help.
In my case you're not squeaking through at an angle. If you fit, you're straight.
Even if I adjust the mirror to see the tires, I still don't see what having the line accomplishes. You need a line to sight against a line. A tire is just a point.
About Truck Camper Group
302 PostsLatest Activity: Sep 07, 2026
