LMHS
Nov 10, 2023Explorer II
Have a center mark on the lower front of the camper floor and a matching mark on the tailgate side of the truck bed (the tail gateis removed. We put it there with a permanent marker and periodically remark it when it fades too much.
Bought a piece of pvc "veranda/trex" porch decking, cut in half to make two pieces, that are used as spacers between the wheel wells. These boards run from the front of the truck bed all the way back to just in front of the rear truck bed pillars. They are slick enough that the camper box will slide down one or the other with little friction. There is about 1/2 inch space on each side between the wheel well + spacer boards and the camper box sides.
I aim for matching up the center marks and the boards tend to push the camper box straight. I do have to watch the grey water tank that is mounted under the galley side so that the top edge of the truck bed doesn't get too close.
It's all a tight fit. I usually take up to 3 tries to get lined up correctly. I normally have my daughter guide me back (it's her camper) but I have loaded it by myself. It's no more difficult than it was to get the popup hitch lined up. If anything, it's easier.
There are also a couple boards laying across the front of the truck bed so the camper box will slide up and touch when it is in far enough. This is because the Stabile Lift has to line up with the saddle brackets that are underneath the truck.
About Truck Camper Group
302 PostsLatest Activity: Sep 07, 2026
