JRscooby
Nov 11, 2023Explorer II
mkirsch wrote:
In my case you're not squeaking through at an angle. If you fit, you're straight.
Even if I adjust the mirror to see the tires, I still don't see what having the line accomplishes. You need a line to sight against a line. A tire is just a point.
Yes, if at angle that squeak will turn into a crash pretty quick.
I park my trailer in the same spot every time I get home. I assume most people want to drop camper in same spot each time. If as you pull out, mark the path your left outside tire takes for say 10 feet past the point you clear the camper you have that 10 feet to get tire following that line as you go under camper. Just be sure camper is up high enough, and it should be a piece of chicken
About Truck Camper Group
302 PostsLatest Activity: Sep 07, 2026
