Lancey
Jul 23, 2023Explorer
Go inside and remove the plywood from under the dinette cousions , and you should be able to see where that tie down in connected to the camper shell, and look close and see if you can follow the water trail, the top clearance lights also like to leak, and the water will flow down the shell to that spot.
The trim on these campers covers the separation between the fiberglass shell and wall insert, these 2 spots do not overlap like northern lite and Bigfoot...so if that trim has pulled away it can leak from there as well.
About Truck Camper Group
300 PostsLatest Activity: Aug 22, 2026
