Westcoastkodiak
Jul 24, 2023Explorer
Hello Peak kodiak sc83, I have the same camper -1995 model- and love it. I took a look at mine and the tie down point in question may be able to be accessed under the kitchen sink. There is a panel under the sink that should provide access to the tie down area.
The sink drains also are in the area above your leak as well as two water lines. It may be possible the leaks are from one of those?
I don't know how your leak test worked out to see if the water is coming from an external source, but it may be worth checking the sink drain plumbing as it is pretty easy to see.
Good luck! - please post the results of your test, would love to hear how you make out.
About Truck Camper Group
300 PostsLatest Activity: Aug 22, 2026
