KodiakSc83
Jul 24, 2023Explorer
Hi Westkodiak! Mine a 98'! Its fun to know that there another owner of this exact camper!
I think the leak came from the front overhang nose trim, i am not sure but time will tell , as when doing a leak test it continued dripping for a couple hours after i did it. The hot water acces is a perfect drip spot too, put caulk and gorilla tape on the inside bottom and isolated that spot by taping plastic over since i knew it leaked too!.put a rubber trim around the edge to slow the water flow inside, in the future i will put an alum drip cap over it.
I can see a sort of rusted steel under the sink drain, it should be the tiedown! I can touch it with the end of my finger. I redid the whole caulking of the camper around every window/light acces door and every trim.the only thing i did not do is to remove all the whole trim to change the butyl tape under it and inspect. Caulked over and under it all around it took around 9 tube of caulk and a can of thinner to clean everything hahaha. I have all the appliance books for the camper and some specs floor plans if you need any infos
About Truck Camper Group
300 PostsLatest Activity: Aug 22, 2026
