KodiakSc83
Jul 28, 2023Explorer
Hello Joe, i did remove every caulk that has been on the camper,started removing what i could with a scrapper and then removed the leftover with paint thinner until there where nothing left anywhere. Then caulk on top and on bottom of the molding trim and around every opening/window/door, The only thing i didn't do because of the 3 day time lapse was to remove all the vinyl insert molding and inspect/caulk and replacing screws with ss screw and bigger one where needed. New insert/screws will be ordered next week when i come back.
The first time i did isolate the leak ive found it one at the front nose of the Tc,after i thought i was good ,it passed the driver side test over windows and front nose driver test after i redid the thing.
I found a little screw that i forgot to put on the fill hose trim maybe that it or not!
I will check everything you guys told me,fill pipe ,inside compartiment. Leaking screws can be the trouble behind the vinyl trim.
About Truck Camper Group
300 PostsLatest Activity: Aug 22, 2026
