notsobigjoe
Jul 28, 2023Nomad III
KodiakSc83 wrote:
Hello Joe, i did remove every caulk that has been on the camper,started removing what i could with a scrapper and then removed the leftover with paint thinner until there where nothing left anywhere. Then caulk on top and on bottom of the molding trim and around every opening/window/door, The only thing i didn't do because of the 3 day time lapse was to remove all the vinyl insert molding and inspect/caulk and replacing screws with ss screw and bigger one where needed. New insert/screws will be ordered next week when i come back.
The first time i did isolate the leak ive found it one at the front nose of the Tc,after i thought i was good ,it passed the driver side test over windows and front nose driver test after i redid the thing.
I found a little screw that i forgot to put on the fill hose trim maybe that it or not!
I will check everything you guys told me,fill pipe ,inside compartiment. Leaking screws can be the trouble behind the vinyl trim.
Ok, Good luck! It sounds like your going to get it if you haven't already. Boy its a pain though. We've all been there and the payoff is worth.
Keep us posted. It always seems to rain when I'm looking for something similar. Lol
About Truck Camper Group
300 PostsLatest Activity: Aug 22, 2026
