New_Mexico_Road's avatar
Nov 14, 2019
Dish TV in Rocky point
Will I be able to get Phoenix local channels on dish sattelite when I travel to Rocky point?
  • If you are out of the spot beam call and change your location to Lukeville,AZ
    It's worth a try.
  • Community Alumni's avatar
    Community Alumni
    Unless it has changed, I used to get my local stations within a 250-300 mile radius when I used to have Dish. If nothing has changed, you should be able to get Phoenix stations in Rocky Point since it's only 170 miles away, as the crow flies.
  • Do a search on "Dish Network spot beam map" and look at images. According to some I found, you should be able to unless Dish locks you out due to your antenna GPS location.
    Rob
  • The one in Mexico. This is the RVing in Mexico and South America forum.
  • There are two Rocky Points in the United States and one in Sonora, Mexico... to which are you referring?
    Rob
