hedgehog48 wrote:
Looking at possibly planning a trip next summer from south eastern Massachusetts to Nashville. Maps look like 95 south to New York, then 287 over tap pan zee bridge . Then 78 into Pennsylvania, 81 to Knoxville tn and then i40 to Nashville. Is this a good route? How is traveling on 81 south versus i95? How bad are the hills? I’m towing a montana fifthwheel with a 6.2 f350 gasser with 4.30 gears. Any input is appreciated.
Just returned from a 4400 mile round trip from SE Ma. to San Antonio Tx.
Departed in the evening at 630 pm. 495 > 90 > 84 > 81 very little traffic made it to Scranton in about 6 hrs. First fuel stop in Danbury Ct. around 170 miles. Exit 8 off 84, Global gas, easy in and out. Second fuel stop just prior to Scranton, exit 8, Liberty Travel Plaza, Mt. Cobb.
A couple of sections E & W bound of 84 in NY west of the Hudson are under construction and reduced to one lane for several miles. Several areas of rough road in both NY. and PA. on 84. Other than that pretty smooth going all the way down to Knoxville.
You should be fine with the hills. Ran into several 3rd gear / 50 mph climbs with my set up. I preferred manually shifting to keep the revs in the sweet spot. Not a big fan of the 5500 rpm, 2nd gear drops while using cruise.
2016 F250 6.2 3.73
2019 Jayco 25.5 REOK (29’ - 9500 lbs.)
