joeburnes
Jun 17, 2017Explorer
2nd A/C in 30 amp 5'er.
I have a 32 foot 5'er that is 30 amp with only one a/c unit. I need to add another unit in the bedroom. There is already a "hole" in the form of a vent. I'm thinking that changing the unit to be able to handle another a/c would take way too much effort and cost (likely having to convert to a 50 amp) so I'm considering having a wire run from the a/c down the outside of the unit (or possibly inside the unit and through a wall) where I can simply "plug it in". Basically, it would have a male connector sticking out so I could feasibly just use a heavy gauge extension chord to plug it into 120 when I need to use the unit (June through September in TEXAS).
Have any of you ever done this? Or know a good resource I could use to reference on how to do this?
