StacyBurleigh
Jun 26, 2013Explorer
30 AMP EMS with 2002 Itasca - want to change to 50 AMP
Guys - Great responses to my dilemma.
Is it possible to hook up a splitter at the source - run the existing 30 Amp cable into the RV EMS and run an alternate 30 Amp (or maybe 30 amp to 20 amp adapter) cable into the RV for additional loads. Seems like the EMS shedding would be bypassed.
Am I trying to split too many hairs here??!
-- (1) central heat / air conditioning system
Thanks Harry
Sitting here in 113 degree Phoenix sunshine at Paradise RV park! Good friend retired master electrician "suggested" changing 30AMP source cable to a 50AMP source cable. This would compensate for heat loss of Volts(AMPs) in existing cable and would provide additional power (AMPs). The current display EMS panel does have a 50 AMP mode available to it.
Manual indicates that EMS system will be disabled if 50 AMP is sourced. Have reflective material on all windows and AC is cycling ok to keep up with cooling (mid day heat causes it to jump to 2nd stage a bit - 27AMP draw).
- What considerations am I missing?
- EMS seems to be a good way to control AMP useage (it sheds load).
- 4 wire 50AMP cable can probably be added relatively easily (with my old time buddies help)
Thx Harry
Thanks Harry
Thx Harry
