tenbear's avatar
tenbear
A different fluorescent to LED conversion
I had a 12v fluorescent light over the bathroom mirror. It was blue and too dim. I decided to convert it to LED.
Here is the original light.
I decided to use LED strips instead of the usual LED panels. Here is a link to the item. After ripping out the guts of the old light I cut the strip into three 15 LED segments and glued them in place with the self sticking backing. Soldering the wires to them was easier than I expected.
Reassembled the fixture and put it back up. Here it is in place.
Now that it is up, it is brighter than I expected. I think I will see if I can frost the lens somehow.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,370 PostsLatest Activity: May 11, 2025
