Just a note:
DC power meters, amp meters etc..
Use Hall Effect sensor to detect direct current magnetic field, a solid state device
AC power meters use CT coils aka Current Transformers
Very old technology,
Alternating current is easy to detect and measure
For many years Direct Current could only be measured with a Shunt using voltage drop over the calibrated resistance,
Hall Effect sensors are not needed for measuring AC, i won't say they can't be used, or have never been used for measuring AC,
Usually pretty easy to tell them apart , small CT that might come with a meter we RV ers would use, normal have just two lead wires and either wire can go in either of the two connection points
They can look like a wrapped up wire coil, or they can be molded in plastic
The HE sensor will be molded and will have a multi pin connector on pickup or on the wire pigtail and be connecting often with a flat multi strand ribbon cable
