nayther's avatar
nayther
ATS wiring
bought this and an inverter from Best Converter:
clicky
I'm not clear on how to wire it. I have 50 amp 4 wire service and a 2,000 watt 3 wire inverter. My thinking is the circuit where the inverter lands gets the "jumper" between the two hot legs, then everything else wires as 4 wire. This way only when the inverter is powering everything are they tied together.
The inverter wires to "generator" and then shore power to the next set of contacts, then the left set goes to the main panel.
Should I remove the silver jumpers on the other 2 sets of contacts?
it did not come with a wiring diagram.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,399 PostsLatest Activity: Dec 30, 2025
