BarneyS wrote:
Here is your picture. I think I would run a garden type hose from the sink to the washout port of the tank (small opening up near the handle with a cap). When ready to dump it, just unscrew the hose, put the cap on the port, take to dump station and hook a regular dump hose from the tank (large port) to the dump hole.
Grey water can and often does smell just as bad or worse than the black tank. I would not run it on the ground unless camped alone in a large remote area. Your neighbors will not like you one bit if you run it on the ground. It is illegal, as far as I know, to do that in any state campground and most private ones. If you leave the caps on until ready to dump there should be no smell problem in the camper.
Barney
![](https://i.imgur.com/VbkZdVol.jpg)
The dumping beside the neighbors is why I figured I'd just haul it back home after each trip and dispose of it at the house. It's only six gallons and I could empty it into a utility sink at home. I really don't expect to use six gallons on one of these trips. If it gets to that point, where I see six gallons isn't cutting it, I'll come up with a different solution. It's not like there will be 5-6 meals prepared each trip, etc... Just briefly washing hands and face, possibly.
I hadn't thought about draining to the small hole, but that would be an easier solution. I'll move in that direction. For now, I'll stick with it staying inside during use. I can give it some test runs in the coming weeks and see if smell becomes a problem.
Thanks to everyone for all the very fast feedback. This has been a fun project. I had a plan when I started, but have had to improvise a lot. I'll probably be posting another question soon about painting the outside.
