Loving_God_s_Co's avatar
Apr 15, 2017
Dayton Ohio area RV carpet installers???
Now that I've died to my carpet dye idea I'm needing suggestions on local area carpet installers who work on RV's. Any suggestions is GREATLY appreciated!!
I already know that some of you will say to do it ourselves but as business owners time is a limited commodity and we would rather keep someone else employed and our free time used by sitting around a campfire!! :)
  • Ron3rd's avatar
    Ron3rd
    Also, they're lots of freelance carpet installers out there with references.
  • METZCOOL wrote:
    If you get ahold of Dave Arborgast in Troy,OH and ask who installs there carpet they will give you there phone number. I did not use them as I ended up finding one closer to do my fifth wheel. Should you want to drive and hour to the north on 75 I can give you his number.
    Sent you a PM :)
  • If you get ahold of Dave Arborgast in Troy,OH and ask who installs there carpet they will give you there phone number. I did not use them as I ended up finding one closer to do my fifth wheel. Should you want to drive and hour to the north on 75 I can give you his number.
  • I have tried Lowe's and Home Depot and a couple of local carpet shops. None of them would do my motorhome even when I called it a Mobile Home (which they will do). As soon as the estimator showed up it was over.
    You are going to have to go to an RV dealer or service location (those that specialize in remodeling helps). I went to Ernie in Weatherford, TX. He is likely the best in the Country and can handle either carpet replacement or wood floors or the change over from 1 to the other.
  • I have already asked one carpet store and they said they do not do that. I haven't checked with any others yet.
  • I would think a normal carpet shop could do it, theres a wood flr under your rv,
About DIY Maintenance
