mdamerell
Feb 25, 2015Explorer
Just a guess, but if you only use one bag it would be harder to control. IE all the air would go to the side with the lower wheel weight. It might want to rock back and forth between the front and rear axle. Fill a zip-lock bag with water and play with it. You'll get the idea. I believe you will find you need separate control/bag for each wheel.
Just to be clear here. Are you making air bags to go under trailer tires to level the camper or making your own air bags for suspension on your truck? If talking about air bags on your truck I have no comment.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,353 PostsLatest Activity: Feb 14, 2025
