Modifying an RV toilet to fit your RV
hedgehopper
Wanting a toilet with an elongated seat in our RV, I looked at everything that Thetford and Dometic had to offer. None would fit. So now I’m wondering about modifying something to fit.
Have you altered an RV toilet to fit in your RV? How did that work out?
12 REPLIES 12
myredracer
If you can get to the underside without removing the coroplast (if present) and a lot of other work, an offset flange would work. You *might* be able to do it from above if you're careful and make a clean cut in the pipe into the tank. I'd use a die grinder with saw blade on it, but if you don't have one, a dremel tool may work but would be slow. A flex shaft on a Dremel may help.
Another solution would be to create a recess in the wall the thickness of whatever the studs are - 1-1/2" or 2-1/2" if the wall has a vent pipe in it. Then trim it out to make it look nice. If the vent pipe happens to be behind the toilet, this wouldn't be possible.
robatthelake
Those toilet flanges can sometimes be repositioned. The other trick is to use a drill and a Dremel tool to grind some new bolt positions in the existing flange.
You may need to use some Original JB Weld to beef it up a wee bit.
Rob & Jean
98 Dutch Star Diesel Pusher ..07 Honda CRV AWD
IAMICHABOD
Maybe try a Offset Flange:@
2006 TIOGA 26Q CHEVY 6.0 WORKHORSE VORTEC
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
hedgehopper
opnspaces wrote:
Do the toilets not fit the flange in the floor? Or are the dimensions of the toilets just too large like maybe they hit the wall or the bathtub?
Bingo! They hit the wall.
opnspaces
Navigator II
Navigator II
enblethen
The Bravura should bolt right in using the correct set of holes. The water line will need to be extended.
What type of flush mechanism is on your current one? Look closely at the Sealand toilets because some of them are odd and require modifications.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
newman_fulltime
Funny all the ones I have installed all have the same bolt pattern.
AppFire
Surprised it don't fit. I have had 3 travel trailers in the last 10 years and replaced all of the toilets with the Bravura. Never had a problem.
2017 Silverado Crew cab LT Max tow package
2003 Jayco Qwest 244
hedgehopper
enblethen wrote:
What is the make and model of your current throne?
Many of the Thetfords are direct replacement.
Toilet conversion chart
It's a Thetford, Aqua-Magic IV, I think. The chart says a Bravura should fit. But it doesn't.
enblethen
Bud
USAF Retired
Pace Arrow
hedgehopper
Dutch_12078 wrote:
In what way don't they fit?
The bases are too big. For example, the Thetford Bravura base is too wide, and if I remember correctly, the mounting holes are too far from the back wall.
Dutch_12078
Dutch
2001 GBM Landau 34' Class A
