brianstrange's avatar
brianstrange
Over cab bunk rot, Serro Scotty Motorhome
Does anyone have pictures of over cab structure on their Serro Scotty Motorhome? I have rot over the drivers side, and as best I can tell, the floor structure consists of a laminated fiberglass panel, with a thin finish panel on top. I can see a 2x2 wood brace that is above the floor level, and ties the two sides together. I'm guessing that that 2x2 also holds the floor, but I cant seem to figure out how the panels are attached. I'd really like to do that before taking it apart. The side frames are aluminum, so I'm assuming that they extend to the front. I'll take some general pic, and post them shortly.
  • Brain, I noticed from other post that your Scotty in on a Dodge Dakota.. mine is a Ram 3500 diesel... might be quite different... what year was it made?
  • I just replaced the front loft area of my Scotty... Sadly I lost the pics when my computer crashed.. The aluminium frame does extend completely around the bed walls.... The floor of the bed is mostly foam with 1/8" plywood glued on both sides and then fiberglass glued to the outside..... I replaced the floor with 3/4" plywood and glued the fiberglass to it. I attached to wall with stainless screws.... in hindsight I might have gone thinner plywood as 3/4 plywood doesn't have much flex. when I attached it to the sidewalls I found that I had a 1" gap at the truck roof attach point... AS my Signature states mine is a 1995.... I've been in contact with other Scotty owner's with newer Rigs and they had aluminum framework across the floor of the loft.... Good Luck with your project
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,352 PostsLatest Activity: Dec 11, 2017
