westend wrote:
Could you describe the saw and the type of wood you are cutting?
As others have said, taping and backing with another piece of wood will bring good results.
A table saw with the correct blade will work the best as the blade turns down into the piece, rather than a miter saw that spins the blade up, into the work.
For trimming, I use a Hitachi miter saw with a new Freud 80T blade. There are better blades but the Freud will not even discolor the cut of a varnished piece, when new, and they are cheaper than other offerings.
I also have a Dozuki but my Bushido is too low for accuracy.
Op here...Thanks to everybody for the replies. (Experts please don't laugh, but here goes)
The type of wood... Well I'm not even sure. It's Home Depot trim. All I know is that it matches my color and is not a compressed cardboard. Last couple of lengths I cut were from a manual miter box with a "back saw". Had better results from when I first stared with a circular saw with a blade that said it was for "finish" work or words to that effect. I was pretty good at following my marked line but the saw sure chewed up the wood near the cut.
This weekend I'm going to a "Rockler" woodworking store near me. They used to give couple hour seminars on different woodworking subjects. I'll see if they still have them available. If so I'll sign up.
Probably be worth my time as I've got a few projects to do in RV and around house. Not to mention I was sort of surprised at the cost of the trim I bought.
(Edit part) just found their class on line. I'm going, (I realize some class will be an advertisement) But after some classes maybe when it comes to finish work it won't look like I used my chain saw.
Thanks
Saturdays
5/30/2015 Rockler Basic Turning: Basic Bowl Turning - 9:30AM
Learn the basics and how easy it is to turn bowls when you are using the right tools and the correct techniques.
5/30/2015 Rockler Innovation Day: Box Joint Jigs - 11AM
Make precise, tight-fitting box joints with your router!
6/6/2015 Rockler Basic Turning: Drawer Slide Installation - 9:30AM
Learn the basics and how easy it is to install drawer slides using the Rockler jig and without the jig by measuring.
6/6/2015 Rockler Innovation Day: Dado & Coping Jigs - 11AM
Cut perfectly fitted dados for a wide range of plywood thicknesses, and see how this Smooth-running coping sled ensures perfectly square coped rail ends with virtually zero tear-out!
6/13/2015 Table Saw Setup and Jigs - 9:30AM
Set up your table saw for accurate cuts and Joints. See the latest Rockler jigs to make using your table saw fast and productive.
6/13/2015 Rockler Innovation Day: Small & Large Box Spline Jigs - 11AM
Dress up your mitered corner joints and add strength too, with the Rockler Router Table Spline Jigs!
6/20/2015 What's Turning Day: Segmented Bowls - 9:30AM
See Jeff create beautiful segmented bowls using his simple jig and Techniques.
6/20/2015 Rockler Innovation Day: Thin Rip, Cove, & Taper Jigs - 11AM
See how these jigs help make ripping thin strips, cutting custom coves, and tapered cuts fast, easy and more precise.
6/27/2015 What's Turning Day: Pen Turning - 9:30AM
Come see how fun & easy it is to turn your own custom made pen!
6/27/2015 21st Century Woodworking: CNC Shark - 11AM
Bring the speed and precision of computer-controlled machinery to your shop with this top value CNC system!
