RTBabich
Nov 30, 2014Explorer
Use Honeywell thermostat to control 2 different heaters
Our trailer has a perfect spot to add an in-wall 120VAC heater, such as a Cadet 1500W 67509. If I understand the thermostat wiring I think I can use our Honeywell digital non-programmable thermostat to control either heater. The Suburban propane heater only uses 2 wires, red & white. The thermostat seems to just connect the red to the white when it is time to turn on the heater. In a house the thermostat would connect 24VAC to the white. In an RV it connects 12VDC to the white. By adding a DPDT switch for the red/white lines the DPDT switch can connect the existing propane heater lines or the new electric heater lines to the thermostat. The electric heater red/white lines would control a 12VDC relay that would switch on 120VAC to run the electric heater. There is 12VDC already in the cabinet where the electric heater would go and I can add one more 15A 120VAC circuit from the power panel. The relay (probably a T92 Potter Brumfield 30A electric heater relay) can be mounted in a junction box in the cabinet. I think the 1.7W relay coil draws less than .2A which would be the current going thru the red/white. Maybe throw a 1A fuse in the red line.
This setup would cut the 120VAC clean at set temp, but I don't think that would be a problem for the electric heater.
Once installed, you would go to the thermostat, select ON, select which heater, set the temp, done.
