rkentzel
Aug 22, 2013Explorer
My 1141 stock trailer bulbs are 18.4 watts and from what I've read, suppose to be approximately 260 lumen. My 1141 TH bulbs put out much much more light than these 24-5050 panels. The 24-5050 should put out over 360 lumen. Either the led ratings are way off, or all led smd 24-5050 panels are not created equally at all, huge difference.
DAWg134 wrote:
"Is this a 24 5050 panel, or did they send me something else...?"
AllCool,
The spec sheet I found for white 5050 LEDs (http://www.wayjun.com/Datasheet/Led/5050%20SMD%20LED.pdf) shows between 14-16 lumens per LED, so 24 ought to yield roughly 360 lumens. The luminous efficacy of a typical incandescent bulb is 16 lumens per watt, so 360 lumens would only be equivalent to a 25W bulb... not particularly bright and considerably less than many of the flashlights I have stashed around the house.
I'm guessing you got what you paid for.
westend wrote:
I would think that .07 is within design standards and it's questionable if that caliper and the measuring points wouldn't have some error (I own the same caliper).
