tlukasavige172's avatar
Jul 06, 2014
Air Conditioner Dripping Inside RV
This morning I heard noise coming from the AC that sounded like debris was caught near the fan and rustling around. I took the white cover off inside the RV to see if I could find anything. When I took the cover off I found the inside of it had a pool of water sitting around the edge. I could pull down slightly on the metal ring that holds the AC to the roof and has the 4 bolts going through it. When I did this I could see signs of water. Also these 4 bolts were loose and I could tighten them with my hand. I found a drip that is coming from behind a metal plate that faces to the rear of the AC (see pic, I'm pointing at the location). It looks like there is a foam seal behind it. I think that's my main drip but the water under the metal ring is also concerning me. I took photos of the roof as it looks like the water is running off it. Wondering what the correct fix for this may be. Thanks
