First Cat Scale Weigh In
allen8106
2018 GMC 3500 DRW
9,375 - GAWR - Rear
5,600 - GAWR - Front
13,025 - GVWR
4,619 - Max Cargo
2010 Jayco 31.5 RLDS 5th Wheel
8,900 - Advertised dry weight
2,120 - Advertised dry pin weight
2,500 - Advertised cargo capacity
11,400 - Advertised GVWR
Loaded for road trip.
Truck and Camper
5,040 - Steer Axle
6,820 - Drive Axle
8,302 - Trailer Axles
20,180 - Gross Weight
Truck Alone
5,040 - Steer Axle
4,060 - Drive Axle
2,760 - Pin Weight
11,080 - Camper Weight
-I found it interesting that the steer axle weight was the same with or without the 5ver hooked on.
-320 lbs under 5ver cargo capacity.
-Truck weight includes, driver, dog, generator, 5ver power cable, blue boy tote, tackle box, fishing poles and cooler.
-2,555 lbs under drive axle weight rating
2010 Eagle Super Lite 315RLDS
2018 GMC Sierra 3500HD 6.6L Duramax
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 68
21 REPLIES 21
Michelle_S
There you go 4619 for your max cargo capacity, sounds a little better.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
rhagfo
Cummins12V98 wrote:
2018 GMC 3500 DRW
9,375 - GAWR - Rear
13,025 - GVWR
The above seems odd to me when my DRW that's 3 years older has these numbers.
2015 RAM DRW
9,750# RAWR ppl
6,000# FAWR
14,000# GVWR
Ron, GM didn’t max out class 3 GVWR on their 3500 DRW until 2020 model year until then they maxed at 13,025.
allen8106
Michelle.S wrote:
Sorry, but there should still be another door label with the wording:
"Total weight of passengers and cargo should not exceed XXXX Lbs"
Found this sticker, didn't originally see the print stating the capacity. Thought it just mentioned tires and pressures. I have updated my original numbers.
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 68
Michelle_S
allen8106
Michelle.S wrote:
Doesn't look like there was a question from the OP, just posting numbers from his first weigh.
I questioned why his 2018 3500 Dually had a cargo cap over 1000 Lbs lighter than mine.
And some others questions some of the other numbers.
The numbers are off the placards/stickers placed by GM.
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 68
Michelle_S
Cummins12V98
2018 GMC 3500 DRW
9,375 - GAWR - Rear
13,025 - GVWR
2015 RAM DRW
9,750# RAWR
6,000# FAWR
14,000# GVWR
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
allen8106
Michelle.S wrote:
allen8106, I have to ask where did you get the 3,719 - Max Cargo??
I have a 2018 High Country 3500 Dually and right from the door pillar mine is Payload 4930 Lbs.
The max cargo came off the factory sticker in the glove compartment.
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 68
allen8106
Super_Dave wrote:
My big question is how many trips across the scales does it take to get all that data?
Two, one with the camper on and one with the camper off. They will allow you to leave return as long as you return within 24 hours.
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 68
allen8106
Old-Biscuit wrote:
Heavy pin ratio.....5vr should track very well w/o any chucking going on
Does it sit level when hooked up/nose high/nose low?
And how is your bed rail clearance----at least 6" (more is better provided 5vr is level)
5th wheel tracks well and we only get a little chucking if we get some rough roads, otherwise it runs pretty smooth 95% of the time.
The 5th wheel sets a little nose high and bed rail clearance is about 5".
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 68
allen8106
I always set my GN and 5th wheel trailer hitch(s) to where it doesn't affect the trucks front axle much if any.
Your 4060 lb drive axle empty weight is one of the highest I've seen even on haulers websites. Is the 4060 lbs number as is from the factory or after you added your stuff in the truck.
The 4060 drive axle weight is all factory, no mods, just the stuff loaded in the bed, hitch, generator, flag pole, blue boy tote, driver, dog and cooler.
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 68
Old-Biscuit
TWO
One for Truck/Trailer combo
THen drop trailer and do truck alone
1st trip roughly $12
2nd weigh $2 if within 24 hrs at same location as 1st
Michelle_S
Cummins12V98
"Heavy pin ratio.....5vr should track very well w/o any chucking going on"
I can attest this is TRUE!!! 6k pin and that baby rides like it's on rails.
