wedge542's avatar
wedge542
help with weight
I got all the numbers but cant figure it all out to get legal, i dont care what its capable of just need to be legal going across scales, this is not a rv but is a gooseneck type 5th wheel flatbed weighs 5600lbs on cat scales truck was 7260 half tank tool box me hooked together 12900 total steer was 4020 drive was 4320 trailer axel was 4560. Trailer is a tri axel with 6000 axels. This is a 2005 f250 crew cab 4x2 6.0 auto single wheel drv with 3150lb tires. Ford shows a 9600lb door sticker gvwr-4850 front/6100 rear and a 23000lb gcwr and a 17000lb max 5th wheel weight, Im trying to figure how much cargo i can legaly put on the trailer that will not over the pin and how much the scales should show when loaded legal, ill be crossing dot scales every state, prob pulled over alot to get scaled. Iknow everybody has there way of figuring but im looking for actual legal dot/fmcsa limits, please keep it simple in laymens terms, i just need to know what i can put on trailer and pin area. thank you
