clev wrote:
I just completed the bond and PROBLEM SOLVED!!! There is no power on the ground side of the plug and 128 volts on the positive blade, only. Regardless of what others have attempted to post, I know the ground side of the plugs in my RV should not have voltage. This bonding on neutral and ground has solved that problem. I am thankful that I purchased the Surge Guard that alerted me to the problem, and to Rusty for his assistance.
Clearly you've not bothered to read through
the discussion I linked to earlier in which one poster (Salvo) explains clearly why you're reading "unusual" voltages which I've already pointed out are phantom and thus irrelevant. To whit -
"The 60V from hot to ground and from neutral to ground are caused by capacitive voltage divider, not inductive coupling. Some electronics (like the converter) have emi capacitors from hot to ground and from neutral to ground. The sum of these two voltages will add up to 120V.
Even though the 60V seems daunting, it is harmless. If you were to measure this voltage with an analog meter you would get about 5V, not 60V. The analog meter has lower input resistance, similar to what the human body has. In other words, if a human grabbed a hold of hot and ground or neutral and ground, they would only "feel" 5V. Of course I'm talking about an inverter that is NOT bonded."So in fact you've solved a "problem" that isn't ... whatever floats your boat. ;)
As to that response from Progressive Industries their recommendation to bond is offered as a
workaround in a situation where their EMS product recognizes a floating neutral as an "error", seeing it as an "open ground", and will thus not pass signal,
not whether G > N bonding is a matter of good electrical practice. That issue is what is discussed in that
41 page thread I linked to earlier and as anyone who has bothered to read that discussion will know not even those much more qualified than any of the rest of us can agree upon.
As far as G > N bonding an inverter output is a "good idea" or not the owner's manual supplied with my own 1000 watt sine wave inverter warns specifically against the practice. Since inverter design varies there is thus no sure way to know whether one can or should bond the output but it seems only logical to me to follow the recommendations from the manufacturer which designed and built that particular unit.
