RoyBell's avatar
RoyBell
How do I move weight forward?
I am looking at side by sides for my 320G. On the scales with no bike/water the trailer has 12,120 lbs on the axles and 2,620 on the pin. With 1500 lbs of water and motorcycle, it shifts the weight to the trailer axles by 2,000 lbs and pulls almost 500 lbs off the pin. 14,120 on axles and 2140 on the pin.
This puts my axles at max load (7000 lb axles) despite being under GVWR.
It appears the water tank is towards the front front half of the garage and the fuel cell is at the rear half.
If I look at a 1700 lb side by side, I would have to run no water. However, it would pull so much weight off the pin, that my axles would be severally overloaded, despite being so much under GVWR. If I put more ballast on the pin, would it offset the weight in the garage?
It just blows my mind that adding 1500 lb to the garage adds 2000 lbs to the trailer axles. Adding 1700-1800 lbs would likely add 2400 lbs to the trailer axles
I have about 7" clearance now to the bedrails. Would lowering the pin an 1-2 inches and going with shorter tires (I have 35s), for another 1" gain transfer enough weight back to the truck to make it worth while? It's a little low in the rear currently which is likely contributing to this problem.
I am not sure what else I could do. There isn't much weight in the garage other than a portable grill and spare tire (maybe 100 lbs total) which I can transfer to front storage. We travel pretty light otherwise.
