Diesel_Camper's avatar
Jan 11, 2015
Just put shocks on 5er, Shocks too short?
These are Monroe 555001's designed for RV use. Once I installed the shocks and then leveled the trailer, there is only about an inch of compression left in the shock's travel. There is only about 3-4 inches between the top of the axle and the bottom of the frame so I know it doesn't use all of that, but I'm not convinced the shocks have enough room to work before bottoming out. I'm thinking I could cut off the upper shock mounts and raise them if needs be. Just not sure if that is necessary for how much travel these axles actually use.
About Fifth Wheel Group
19,006 PostsLatest Activity: Jan 24, 2025
