Need some advice, went to leave yesterday and the rear levelers did not retract, display, (lippert 2.0 ground control) said "jacks up"! Looked everywhere for a fuse or reset button, could not fins any. Front worked fine, so I swapped the wires at control box, and got the left rear up. Right rear refused to budge. I do not have a crank to manually retract the levelers, Tried to use my portable drill, battery to low. Used a vice grip to turn the handle, but that was going to take hours, at half turn per grip! Decided that we were not leaving, put wires back, and hit auto level. All jacks were working, so hit retract rear, they worked, got hitched, and a retract all pulled them all up. When we got to our destination all worked perfectly!
Anyone have this happen to them before? Any suggestions as to the cause and/or fix? And lastly, when retracting manually which direction do you turn, clockwise or counter clockwise? Thanks your input will be appreciated!
