Cummins12V98 wrote:
NEVER would anyone place a 5er hitch behind the rear axle in the days of drilling and bolting down your own hitch.
Can you run behind your rear axle? Sure and some do. Doesn't make it the best choice.
I would consider a PulRite steel or Andersen steel version in the normal ahead of axle position if towing a light 5er. The aluminum version at 24k is a JOKE and WILL cause bed deflection towing a heavy 5er.
OP do your research, you will find the happiest are B&W hitch owners. ZERO question if you are hitched or not with a simple solid latching system and no silly color coded latching.
Oh and another thing, no one has shown a good way to lock your hitch to the RV with an Andersen.
I won't go any further on this Andersen hitch in front or behind the axle, but speaking from experience you are wrong, and its done every day. We go thru this every time the subject comes up. If you have towed with the Andersen ,then you would know.
As far as locking the hitch, not sure what you mean, I don't lock my conventional hitch ,nor do I worry about locking this Andersen , but if you mean the latch ,its a pretty positive lock, and turn. There are a few things I do, and I do EVERY time I leave my fifth wheel ,and truck unattended. I check the tires, lights, and make sure the hitch is as I left it latched, and ready to go. I think it foolish not too. I don't need a pile of padlocks, and keys to make sure my hitch is still latched ,and no one has messed with it. Its part of towing anything, and it does not require padlocks .
