Njmurvin's avatar
Njmurvin
Jul 22, 2016
Lubing bevel gears in landing gear legs
I believe my landing gear are the standard Lippert type. I have the single motor system. The landing gear motor sounds like it's working way too hard to lift the front of the trailer. I have already drilled holes just above the first leg support bracket on each side and injected white lithium grease onto the leadscrew. While still on the truck, I ran the gear up and down several times and things quieted down significantly with no load on the gear. With the load of the trailer, it is definitely improved after lubing (doesn't stop and trip the breaker or break the shaft bolt). However, I think it's still moaning and groaning more than it should and the motor seems to be straining an awful lot. Before I bite the bullet and install a dual motor system (Bulldog, etc.), I thought I would try to lube the bevel gears at the tops of the legs. Can I just pry the top caps of the legs off with a screwdriver and squirt some lube down from the top?
FWIW, when the bolt had sheared off on the shaft going to the trail leg, I was able to easily raise the trailer using just the lead leg (fairly quiet with little strain on the motor). Doesn't this suggest there's an issue in the trail leg?
