twvette
Dec 07, 2015Explorer
Main DC inline fuse and/or holder is melting
My Weekend Warrior toy hauler main DC power line has an inline fuse about foot away from battery and the fuse holder is getting really hot and starts to melt. It wont actually trip the fuse for a while even with the bulk of the fuse holder or fuse plastic itself melted. Just the fuse holder/fuse is getting hot for the most part, not the wiring for most part. This ONLY occurs when my Onan 5500 is running. I know when its about to happen as my charging voltage seen through my solar charging system is not very high (like 12.3v vs. normal 13 to 14V). It kills all DC power to the trailer when the fuse eventually does pop so it is my main line and the line the battery charge of generator comes through. Its 8ga wire and I inspected the wire runs and see nothing unusual or obvious shorting. Generator goes through an Iota DLS-45. This model says max output of 45 amps and the inline fuse was originally the large style maxi fuse 40 amp. Could the too small of fuse cause the heat? Seems a little unlikely as doubt it really is at max output.
To get through my last trip I sparingly ran the generator and wired in a more typical ATO size inline fuse holder. The max amp fuse I could get again was a 40 amp. This fuse holder was not melting but was also getting very hot but the fuse plastic itself melts internally and will also eventually pop the fuse.
Just too small of fuse? Maybe I had really bad luck with two separate fuse holders not making good contact and high resistance creating heat (second one was a friends used one from bottom of his tool box but seemed in good shape)?
I am taking with me next time I go camping (toy hauler in storage far away) a thermal imager to inspect all wiring and a DC amp clamp to do some more better troubleshooting but wanted to pick some brains of things to look for? I did purchase a 50a circuit breaker that is probably much better than an inline fuse anyway and if nothing else will save me from going through a bunch of fuses.
I have not changed anything on the electrical for a long time now so a bit baffled. There is a solar system (just one panel) and I do have a 2k inverter but nothing gets hot unless the generator is also running.
