dustinl
Jan 12, 2020Explorer
melting plug
in the past 14 months i have had to replace the 30A plug that plugs into the rv parks box at least 3 times because 1 of the prongs overheats and melts my plug. need ideas on what might be the cause
OP has not been back in like 8 days, if same park, bad pedestal outlet. Different parks likely too much draw.
How do you draw too much without tripping the parks breaker?
enblethen wrote:
I went to Smartplug website. I saw nothing indicating Coast Guard, NEMA, UL or NEC approval.
pianotuna wrote:
Why is this "new" plug better than the current standard for RV's? Does it have greater surface area on the female contacts?
enblethen wrote:
It will be a very long time for the "Smart Plug" be approved by NEMA.
Me Again wrote:ScottG wrote:
It's sad but the industry's NEMA TT30R/P design is really under engineered IMHO. Many decades ago when it was created, there were no electric water heaters (in RV's) or micros, TV's, large battery chargers, etc. Just some lights and the occasional space heater. Then add in poor quality, off shore parts and it only gets worse.
We use a lot more of the capacity if these "trailer" circuits now and while they work OK when everything is perfect, they don't like running a constant load at anywhere close to their 30A rating.
It's too bad we can't switch over to the marine undustrys 30A receptacle for pedestals. It seems to hold up better.
The 30A twist lock used in marinas is worst than the RV 30. It is a 80 or 90 year old hospital design and routinely causes marina fires.
This is the new plug for marinas, however it would take years to convert everybody.
https://www.westmarine.com/buy/smartplug--combo-inlet-connector-30a-125v-white--17415258?&mrkgcl=481&mrkgadid=3202694706&cm_mmc=PS-_-Google-_-GSC%3ENonB%3EProduct%2520Type-_-17415258&product_id=17415258&creative=108421552324&device=c&matchtype=&network=g&lid=92700049310972060&ds_s_kwgid=58700005416296602&ds_e_product_group_id=301382160878&ds_e_product_store_id=&ds_e_ad_type=pla&ds_s_inventory_feed_id=97700000007545409&gclid=EAIaIQobChMIt-323veQ5wIVEf5kCh3GfQzyEAQYAiABEgK1FPD_BwE&gclsrc=aw.ds
