howardwheeler
Jan 08, 2014Explorer
Odd Repetitive Trouble with my Alpenlite brakes
I have Neverlube Dexter hubs that came with the fifthwheel that are rated at 8000 lbs per axle, though the Alpenlite trailer literature says I only have 7000 lbs axles. I don't know why that is, and it's probably irrelevant. I'm glad I have big brakes because it's a heavy 16000 lbs trailer. Anyway I started losing my brakes on my last trip of around 600 miles. Scary! Upon checking them back home, one magnet was no good, drawing no amps, but the odd thing is that my passenger side front brakes had no lining left at all. All other hubs had great lining. The oddity is that three years ago on a trip to the Canadian Rockies (if you've never been, go!) my brake on the same hub locked up. We dismantled it in the Banff campground (fun) and discovered that the brake lining had come loose from their metal backing and just jammed the whole hub. This is the same hub that once again has lost all the lining. I don't know if they fell off again (we replace the entire backing assembly with a new one we found in Calgary), or if they just wore down, but they were gone and it was metal to metal. What's happening on that hub? Tires all wear evenly, but for some reason that hub gives out. This time, we also found a questionable ground connection where the brake wires first connect with the wires that then go to each brake. It seemed corroded. We are redoing each wiring connection, but we don't really know if any were really bad. So, does anyone have an idea about why that hub does this while all the other brake lings look great? The hubs are 12.25x3.375.
