sportsman_500
Aug 20, 2017Explorer
Onan Generator Heat
On my Raptor 3612 the generator compartment is designed probably like every other one out there. Over the weekend we were running the genny almost non-stop. On Friday night I was checking a few things and noticed the generator compartment door was very hot to the point where you almost could not touch it. When I opened the door I found that the inside liner had deformed from the heat and on the lower right hand corner of the generator there is a horseshoe shaped opening. Super hot air was blasting out of that opening onto the inside of the compartment door. Has anyone else experienced this? Is that hole on the right lower supposed to be blocked off? or is it part of the generator cooling system?
Edited Images to fit the page.
