woodtrucker
Sep 28, 2018Explorer
RV black tank outlet plumbing
After 4 years of ownership and many happy miles pulling the 5, I've spring a leak in the worst place. sewer...
I think it happened over winter when I forgot to drain black tank completely and it cracked a pipe. Looks like the crack runs the full length of this section. see attached.
I also noticed a U shape crack about 1/4" out from the flange OD of outlet flange exit of black tank. It was repaired with caulk in the past and I think I'm gonna clean it up and to some fiberglass/epoxy resin to seal that back up right.
As for the exit pipe between second elbow and valve, it's a about a long crack. Could I repair the same way possibly or would that kind of length be too risky to repair with fiberglass/epoxy trick?
Any other suggestions beside replacing everything?
link below to a pic
https://ibb.co/eahWe9
link below to a pic
