โMay-11-2016 10:11 AM
โMay-14-2016 04:43 PM
โMay-13-2016 06:04 AM
davisenvy wrote:
I guess I have to decide weather the 1.5" I'll gain from the new hitch is worth $300. I'm a little concerned lowering the hitch point might cause some bed rail/kingpin clearance. Then if I do rotate the coupler, I might run into cab/nose cone issues. I have decided to trim the fiberglass around the kingpin to give me another inch. That and the spring lift will give me 3 inches closer to level leaving the nose 2 in high.
โMay-13-2016 03:07 AM
โMay-13-2016 02:43 AM
โMay-12-2016 08:31 AM
Me Again wrote:
So raise it on the springs first before spending money and see where you are at.
If you have a 20' board that is 5" off level, then raising the center of the board 2.5" will make level, assuming the high remains stationary.
Some people are installing the bolt on version of Correct Track, which raises the trailer.
http://www.lci1.com/correct-track-ii
Chris
โMay-12-2016 07:59 AM
Chris
โMay-12-2016 07:45 AM
davisenvy wrote:
The trailer is high 5 inches from the rear to just behind the nose cone. I'm measuring from the the skirt on the FW. I'm going to raise the FW 2 in and lower the nose 2 in.
โMay-12-2016 07:38 AM
โMay-12-2016 06:33 AM
โMay-12-2016 06:15 AM
โMay-12-2016 04:15 AM
โMay-11-2016 07:49 PM
davisenvy wrote:
I have the pinbox up as high as the FW will allow and I'm still towing nose high by 5 inches.
โMay-11-2016 07:07 PM
davisenvy wrote:
Chris, forgive my ignorance, but what are the jack plates?
My plan is to go down some in the front and up some with the leaf springs. This should get me pretty close to level.
โMay-11-2016 06:55 PM
