twodownzero wrote:
camp-n-family wrote:
twodownzero wrote:
I think you should be much more concerned that the manufacturer's claims of "1/2 ton tow-able" are nonsense and that you likely lack sufficient payload to pull any 5th wheel that big with your truck, especially if it has a 4 door cab, 4wd, and you plan on having passengers in the cab with.
He’s not towing it with a half ton, just looking at “ half ton towable” models. OP has a Ram 2500 which is plenty of truck.
I looked up the published weights on their website, and my common sense determined that to be a lie.
OMG! OMG! that 5er is too much for your TV!
I think the OP will be just fine. the OPs TV is a 2017 Ram, 2500, 6.4 Hemi, 4X4 he likely has near 3,000# of payload.
Reflection 29RS Specs
UVW1 8,816 lbs
Hitch Weight 1,538 lbs
GVWR 11,495 lbs
Length 30' 11"
Height 12' 3"
Even at full GVWR and a 22% pin weight it would only be 2,530#, that is only if the OP can stuff 2,679# of stuff in its 31' length.
I for one tow our 32' 5er at 12,500# with a 2001 Ram 2500 CTD, with a 8,800# GVWR. I ran 1,700# over GVWR, but under both axle and tire ratings, never an issue.
I did get a new TV for a future 5er, that is a 2016 Ram 3500 DRW CTD, and will say with the same 5er in tow I need to check the mirrors to see if it is still back there.
