jwstrout's avatar
jwstrout
Trailer Tires
Hello All,
I am new here, and I am not sure if I am posting my question in the proper area, So please forgive my ignorance.
I have a 2006 Starcraft Travelstar 18SD. It is a hybrid toy hauler, with an open toy deck on the front. Tongue to rear bumper, the trailer is approximately 29' long, and is equipped with tandem 3500# axles. Tongue weight is 494#, dry weight is 3860#, loaded weight is 4381#, and gross weight is 7100#.
Currently, I am still running the stock tires, which are 235/75/15C Dunlop Radial Mud Rovers. (yes, mud terrain tires) The tires are in need of replacement.
So here is my question.....
As far as the stock tire size is concerned, selection is fairly limited, for what I would consider a quality brand tire.
First Option : I have found some Goodyear Wrangler Radial tires in the aforementioned size. They are rated at 2028# each, at 35 PSI.
Second Option : I change to a 225/75/15 trailer tire, with a load rating of C or D. My concern with these is speed rating. Don't get me wrong, I don't want to run down the road at unsafe speeds. But the speed rating on trailer tires spooks me a little.
Third Option : An educated suggestion from one of you fine forum members.
Thanks in advance,
Jeff
