- Me_AgainExplorer IIIBTW, if anyone has a similar 1996 M-40RLTSO(or other year) that can provide some info that would be great.
GVWR?
GAWR?
Fresh Water Capacity
Black Water Capacity
Grey Water Capacity
And any other details, as the placard is not readable!
Chris - Me_AgainExplorer III
MFL wrote:
Good follow up Chris. I'm glad to hear it all went well!
It must have been a good load on the 350. It may have been 7000+ on the RA.
Hope the family gets some good use from it!
Jerry
It is a bit of a box of surprises on wheels!!! The solenoid for the ice marker had frozen and linked water, so we had to remove it and block the water line.
Striker on the stove top needs replacement, as it got hot and sticks.
Dead bolt was all broken up inside so we had to install a new one.
Sat dish removed from roof without sealing the screw holes. Jeff is going to get a tube of Dicor and seal these and over areas.
Broken doors on the shore power cord and truck cable.
Someone put 50 AMP RV power on the lot without a circuit breaker?? Lot has two 30RV outlets and that do have the correct breakers. 200Amp panel with main breaker. Has a GFI 15/20amp conv outlet in panel with no breaker!!
Positive! The seller installed 6 new Gladiator LRG tires. With two deep opposing slide the living room is really big.
It has a black tank wash connection.
Actually for a 1996 trailer it has a lot of "modern" features!
We positioned it so the sewer connection is under the front of the trailer just behind landing gear. This will keep the sewer hose out of the Eastern Washington summer sun.
The lot is big enough that we were able to drive right around the trailer as we ran for supplies, lunch and go play 9 holes at the Desert Aire county golf course, on the Columbia River.
Chris - MFLNomad IIGood follow up Chris. I'm glad to hear it all went well!
Jerry - Me_AgainExplorer IIIWell, we had it delivered yesterday and got it set up. Spent several hours fixing issue and making a list of needed items.
Delivery was with a SRW F350 with tires rated to 3750. It was squatting a bit, however no air bags.
Looks like dry pin weight was 3500-4000.
Chris - brose38Explorer
Me Again wrote:
brose38 wrote:
https://plus.google.com/u/0/photos/yourphotos?pid=5978124124227864098&oid=117531372823408312278
I hate to tell you this, however I have a 2000 much like your 1996. Here is a link to my sticker for my trailer. My hitch weigh is about 4600# I tow with an International 4400. These trailer are built heavy.
Do you know you dry pin weight? This does not have washer or dryer, it does however have a generator. Other than that it is bare. But sounds like we need to hire some to move it.
I can not view your picture for some reason. I will try sending you a PM with an email address. Chris
I don't know what the dry weight is, but I do have a washer dryer, however your generator is in the front and close to the pin, my washer is further back. - cummins2014Explorer
Me Again wrote:
Well at this point we are looking into having it delivered the 126 miles. Chris
Smart move - Me_AgainExplorer IIIWell at this point we are looking into having it delivered the 126 miles. Chris
- larry_barnhartExplorerWe know a couple that had about the biggest TS made and the truck was a f-250 diesel. 1999 model year. It was ugly but full timing and carrying concrete pigs made for a heavy rv. That is what I call brain dead.
chevman - rhagfoExplorer III
larry barnhart wrote:
for years I have been told from the owners of a 2500 dodge, it can pull anything out there but of course they were brain dead and did not understand the carrying the load part of towing. My guess is your truck can do what you want for that tow.
chevman
Well sure we are not "Brain Dead". Just happen to own one of the most over sprung, under rated TV out there.
The 2nd gen 2500, had a 8,800# GVWR, adding the Camper Package included larger tires, and one ton springs, but nothing changed on the VIN sticker! Tires listed as 245/75-16E's Build sheet states came with 265/75-16E's. I carry my load without bags, 11,000# 5er no issues. Stopping is no issue also, plenty of brake!
Pull heck yes, last weekend got stuck in the stop and go traffic in Lincoln City, OR, very hilly, idled up one with the truck in 1st an my foot sitting on the floor. - larry_barnhartExplorerfor years I have been told from the owners of a 2500 dodge, it can pull anything out there but of course they were brain dead and did not understand the carrying the load part of towing. My guess is your truck can do what you want for that tow.
chevman
About Fifth Wheel Group
19,006 PostsLatest Activity: Feb 16, 2025
