- rrbowmanExplorer
aruba wrote:
Hi,
The picture below show a device that is in the battery compartment of my 2010 Keystone Cougar. What is it called?
I have power going into the "+" terminal, but no power output to any of the output terminals. Is there a main fuse or breaker for this? a reset button?
Thanks.
It looks like you have a Lippert Remote control system, if you contact Customer Service at Lippert they will probably send you a new remote and instructions on how to pair the new remote to your control panel. By the way it is very handy especially in hooking up your camper and unhooking. - arubaExplorerThe landing gears are connected to the terminals in the picture that says "manual". A few days ago, using the rocker switch, the landing gears would not work. I unhooked the wires from control box and wired them to the battery and the landing gears worked again. That is why I attribute the box not working.
I never got a remote when I bought the 5'er used, so I can't test the other terminals. - Water-BugExplorer II
aruba wrote:
Hi,
Thanks.
Do you have anything that isn't working? Lots of devices have power in and nothing on the output, if nothing is activating them. (Be it a remote, on/off switch or sensor). - BemotaExplorerHi, I took some pic's of the control panel, the pen is pointing to the location of my remote in storage. by recessed I ment that it is flush with the front of the panel, there are places to get your fingers in there to get it out. I took it out and took a pic of it with a tape so you get an idea of it's size. I also took a pic of my box, the power comes in on the right and the slides, awning and lights are on the left, that's what I figured out so far. Hope this helps :) Dan
PS HELP how do I attach pic's - arubaExplorerHi Bemota,
Can you clarify where it is located? I am not sure what you mean by the recess by the slide control.
The previous owner never gave me a remote nor mentioned it. I have owned the unit for 3 years and have never seen a remote? Anyone have a picture?
Thanks. - BemotaExplorerHi ! I just got a 2011 Cougar, still playing with things, anyway, I have a similar box. Finally figured it out, it's a "Cougar Multi- Function Remote", the remote control is located in a recess at the bottom of the control for the slides etc. Mine is held in place with Velcro, it controls the four slides, landing gear, awning, and some lights, has a built-in flashlight. You can operate slides while outside watching for obstructions. So far I like it. Dan
- shepstoneExploreryes its for a remote control we have something similar in ours
- Dakota98ExplorerI'm guessing you don't have the "remote" for it.
- ChandalenExplorerLooks like the 'EZ Camp Cougar' Remote control box.
If this is it, it allows the slides/awnings and auto levelers (if equipped) to be opened via a remote control. Isnt that fancy?
The output terminals most likely wire right to the motors of the slide/awning that they control. The Manual Switches allows the buttons inside to work. When activated the box will give power to the appropriate output.
A built in mirror and dual automotive LED docking lights are all you need to align your truck to a Cougar’s extended hitch pin. This can be controlled by using the E-Z Camp Cougar Remote, a remote control providing a convenient way to control your docking light, electric slide out, landing gear and electric awning! The remote even comes with a high emittance LED flashlight!
About Fifth Wheel Group
19,007 PostsLatest Activity: Feb 26, 2025
