Dec-01-2013 02:04 PM
Dec-07-2013 04:48 PM
Dec-07-2013 07:04 AM
Dec-07-2013 04:16 AM
Dec-06-2013 01:16 PM
Gib3633 wrote:
Much as I hate I have to ask. PS. I know fifth wheels don't have rear ends. Why is it that axle bearings NEED freeplay when Pinion bearing have a preload of 50 inch lbs of rolling torque just 3 feet from the axle bearings. Pinion bearings often last half a million miles with only a couple of oil changes. I know you can't allow the pinion to walk back and forth in the crown gear . The carrier bearings also have preload . That said my vote is with Scott G.
Dec-06-2013 12:36 PM
Dec-06-2013 11:50 AM
Dec-06-2013 07:11 AM
Slownsy wrote:
There is no end play in newer lube bearings they are to be torked to 150 feet pound, the tolerances is for wear in bearings as they can not be adjusted but must be replaced.
Frank.
Dec-06-2013 04:03 AM
Dec-05-2013 04:19 AM
Slownsy wrote:.
Frank.
Dec-05-2013 03:55 AM
Dec-04-2013 04:33 PM
Dec-04-2013 05:49 AM
JIMNLIN wrote:
A small amount of bearing play is normal and required on a trailers axles. In fact bearing will last longer with a small bit of play. Bearings should never be tight.
This from Dexter on "bearing adjustment and play".
Bearing Adjustment and Hub Replacement
if the hub has been removed or bearing adjustment is required, the following adjustment procedure must be allowed:
1. After placing the hub, bearings, washers, and spindle nut back on the axle spindle in reverse order as detailed in the previous section on hub removal, rotate the hub assembly slowly while tightening the spindle nut to approximately 50 lbs.{t (12" wrench or pliers with full hand force).
2. Then loosen the spindle nut to remove the torque. Do not rotate the hub.
3. Finger tighten the spindle nut until just snug.
4. Back the spindle nut out slightly until the first castellation lines up with the cotter key hole and insert the cotter pin (or locking tang in the case
of E-Z Lube TM).
5. Bend over the cotter pin legs to secure the nut (or locking tang in the case ol E-Z Lube TM).
6. Nut should be free to move with only restraint being the cotter pin (or locking tang).
And proper bearing end play;
Nev-R-Lube Bearing End Play inspection.
The following lists the maximum axial end play for each of the sizes of, Nev-R-Lube bearings and the amount of tilt that can be expected, Since there are a large number of wheel and tire combinations in use on trailers, the tilt is expressed in inches per inch. The movement as measured at the tire tread can be found by the following method:
Example: if the tilt value is shown as .003" per inch and the tire measures 30" in diameter, simply multiply .003' X 30' = .090" which is the total expected movement at the tires' outer diameter.
Bearing size End play resultant tilt value
35 MM .005" axial .003'7 per inch
42 MM .006" axial .005"/ per inch
50 MM .O08" axial .004"/ per inch
the above is a snipped copy and paste from Dexters "hubs/drums and bearing" PDF
Dec-04-2013 04:34 AM
of E-Z Lube TM).
Dec-04-2013 04:27 AM
jbcason wrote:
If u used a whole tube of grease on one wheel the seal is leaking inside onto the brakes. Bearings need to be adjusted periodically. Doesn't mean they are worn out. Should pull , clean, and inspect every so often also.
