Check tightness of allen head set screws at converter/charger output terminal block. Check for 13.6 volt DC output at the same terminals. Check for any blown fuses or open circuit breakers between converter/charger and house batteries. That control center may have some sort of house battery disconnect/connect button connected to a latching relay near the house batteries. You should hear it snap when you push the house battery disconnect/connect button. These gizmos go bad and stick open. You may need to get help from a local RV service.Old RV's often have tricky electrical problems caused by corroded or loose connections or aging parts.
