Jun-19-2018 04:41 PM
Jun-27-2018 07:42 PM
DrewE wrote:norwestie wrote:
UPDATE
I took her to a repair shop I trust yesterday. Got a call later in the day that they were 99% sure they found the problem. Two of the house batteries were dead or close to it. He explained that when plugged into the 50 amp service, the inverter was trying so hard to charge the dead batteries that it caused havoc with the whole 120v system.
It may well be that the batteries were dead and in need of replacement, but this explanation is hogwash if the 120V electrical system is operating properly. The inverter (I assume it's an inverter/charger) would be a reasonably heavy load on one of the legs, but that should in no way cause the voltage in the other leg to skyrocket...or, for that matter, the voltage in its leg to sag too much. If it consumed too much current, it would just trip a circuit breaker somewhere. The only way you could see such swings are if there's a bad connection somewhere, be it in the RV or the campground wiring.
Did they even check that the neutral connections were good and tight in the circuit breaker box on the RV?
Jun-27-2018 05:12 PM
norwestie wrote:
UPDATE
Jun-27-2018 03:30 PM
Bud
USAF Retired
Pace Arrow
Jun-27-2018 03:25 PM
Jun-24-2018 08:18 AM
Jun-22-2018 09:07 AM
norwestie wrote:
We plugging in to the 50A on the pedestal at a campground Sunday. Here is what happened right after:
(all related to 120VAC):
Several outlets dead
Vacuum cleaner pitch changed up and down when in use
Tower fan burned out (electrical odor noticed)
Coffee machine burned out, smoked noted
Touching exterior door handle, received mild shock
After the fan died and outlets not working, I reported the issue to the camp host. Maintenance man changed the 50 amp receptacle and checked voltage on all legs. All measured normal. When I reconnected, same problems noticed. I tried using my 50A-to-30A adapter and there was no AC power in the coach at all. I then disconnected shore power and ran the generator. Same lack of AC on various outlets. After I received a shock from the door handle, we ran from battery power only.
Perhaps unrelated but when I connected this RV at my home (before this trip) to a 15 amp 120VAC circuit, my GFCI would trip. My previous RV ran fine on the same circuit.
Do all of these point to one issue? I suspect the transfer switch but trust your input.
Jun-21-2018 06:05 PM
Jun-21-2018 05:48 PM
Jun-21-2018 04:14 PM
Jun-21-2018 06:03 AM
Jun-20-2018 04:50 AM
Jun-19-2018 11:31 PM
KD4UPL wrote:
There almost has too be two issues here.
I agree, the campground pedestal was probably mis-wired or had an open neutral. This would fry some things.
However, since your RV was tripping the GFCI at your home BEFORE this trip then I suspect you also have a ground fault in the RV. You should have investigated the problem then, at home.
It's possible that the combination of an RV ground fault and a mis-wired pedestal caused more home than it otherwise would have.
Jun-19-2018 07:13 PM
Jun-19-2018 06:56 PM
