Kit Carson wrote:
Thanks everyone for your quick replies. Tenbear, I do have a multimeter, but not real knowledgeable how to work a lot of it. How would I go about checking for short circuit with it?
Your multimeter should have one or several ranges for measuring resistance, or ohms. The symbol for ohms looks like a horseshoe with the opening down. It may have several ranges in the ohms section, select the lowest range. The highest may be something like 2000k, the lowest, just plain 200. Put your probes in the connector labeled with an ohms symbol and the common (COM) connector. When you touch the probes together the meter should read 0.0 or a very small number. That indicates a very small resistance, or short circuit.
Now, with the power off, put the probes on the connectors that you want to check if there is a short between. For example, the contacts for the problem light socket with no light, the switch off and/or the fuse removed. If the ohmmeter reads 0.0 or a very small number, there is a short, either in the socket or the wiring to it. If no short, maybe the bulb has a short. If checking the LED for a short, remember the LED is polarity sensitive, so reverse the leads and see if it still indicates a short.
I hope this makes sense. Let me know how it goes.
2010 Subaru Impreza Sedan
